Re: Board PCBs
Posted: Fri Dec 19, 2014 1:48 am
Finally we need to make sure the drive signal is going to reach all the coil PCBs as a failure here will destroy the driver transistors on one or more coil PCBs.
These are driven in pairs either side of the spine PCB and you'll need to check the voltage between the centre pin and ground of each pair as shown here:
Be VERY careful not to let the meter probe slip, if you short the centre driver pin to the 12V supply it will damage IC1 on that baord and possibly D1 and IC2.
Repeat for all 8 pairs of connections though you only need to test one side as they're linked together, depending on your meter the exact voltage will vary but should be about 2V.
