Time to assemble the sockets. Using wirecutters or pliers carefully break the turned pin sockets out of the plastic housing:
Push the pins into the socket former - Use this pattern of pins for IN-14 nixies:
For IN-8-2 tubes move the anode (at the bottom, 6 o'clock position) to the empty hole on the left.
The decimal points aren't used on any tube so cut this lead short. For IN-8-2 tubes, you'll need to bring the k1 pin across to the unused socket under the DP pin.
You'll need 5 of these made up, either 5x IN-14 tubes or 4x IN-8-2 and 1x IN-14.
Solder them into the PCB - the pins will just clear the holes with the former resting on the LED. If you're using IN-8-2 tubes the single IN-14 socket is used in the centre for the colon IN-19 tube.
